So picked up a plow for super cheap. Needed some work but got it ready. It is an older cycle country. My question is am I tied to only that manufacturer for the mount or can any manufacturers mount work with this push tube?
There are a few different styles of mounts. The hard part would be figuring out what might work with what you have.
Providing as much detail as possible would be helpful. What machine are you wanting to mount it on?
Pics of the tubes where they pin to the mount would be helpful as well
At work so had the wife go take some pictures. Attaching to a 98 sportsman 500. The pushtubes are cycle country as well. Just wasn't sure if I was tied to just that manufacturer for the mount or if I can use any other manufacturer. First atv and plow so still learning a lot.
Quite often, there might be quite a few differences in the mounts.
Do you have a mount for?
Don’t give up on it. You may be able to get the mount to fit with a bit of work
Oh I found the one for it. Was hoping to get one a touch cheaper :grin. Actually there are 2 for the Cycle Country plow I have. Plus I have a second plow coming for free which I believe is the same one as this one.
