Is the driveway paved with gravel at the edges? If so then disregard setting the plow at 1 1/2 above or using the plow shoes. As mentioned above mark the edges to avoid the gravel. After a few times you will be a pro and the gravel won't even be an issue. Just take your time.im plowing my driveway and first time i plowed this one. It has rocks along both sides. Do yall have any tricks to not have 3000 rocks in your yard after plowing?
driveway is black top. Ill monkey around with your guys ideas. Did it once and rocks everywhere lolIs the driveway paved with gravel at the edges? If so then disregard setting the plow at 1 1/2 above or using the plow shoes. As mentioned above mark the edges to avoid the gravel. After a few times you will be a pro and the gravel won't even be an issue. Just take your time.im plowing my driveway and first time i plowed this one. It has rocks along both sides. Do yall have any tricks to not have 3000 rocks in your yard after plowing?
