1 - 10 of 10 Posts
Hey guys wondering what everyone is doing to get traction while plowing ? I was thinking tire chains but i wasent sure. Im looking to push the snow/more snow further before the tires loose traction. Any help or tips is great!
Thanks, Jake
what kind of tires to you have? Im running maxxis zillas and have no problem pushing snow as far as i want
I've never needed chains. I added weight to the rear a couple of years ago with an ammo can full of lead ingots. Had some ice on my hill and would spin backing up.
Discussion Starter · #4 ·
Im currently running stock pxt radials... Im saving the new AMS slingshots till spring.
I put 3/8" sheet metal screws in my tires with hex heads works great in stock tires
- 60lb sandbag on front and rear rack
Me. :)
I have the stock Carlyle tires and if I need some more traction I have taken my rear cargo box off and put 1 40lb and 2 20lb bags of ice salt on the back and tied them down. They stayed put real well. I had the salt bags anyways. I had thought of putting one or two of the bags right in the cargo box, but was concerned about the plastic being able to handle it.
I run chains on rear of mine. Works great but be easy on throttle, they will bite so hard that axles will blow. I just shattered the LR on mine yesterday.
I'd switch from stock tires or install rear tire chains....
1 - 10 of 10 Posts
