Found this old Gal from scrapmetal dealer. W948130 was modelnumber. It needs little cleaning and fixing. Seller said that it wont give good spark inside of cylinder but if spark is tested outside of cylinder, the spark is good. Cdi and sparkplug is brandnew.
And second. What is meaning for that little microswitch what is located on Gaslever housing. 2wires, red and white. Both are cut away from microswitch and pulled off from connectorboard.
Wheel Tire Automotive tire Automotive lighting Vehicle
Now whatched little closer on daylight. All plasticparts are in very cood condition and nothing missing of them. Tank top cover and sidecover were at my car trunk when i took the pic. Drivelight is broken . Seatcover is not torn, dried or scratched. Very easy project.
2004 Sportsman 700, 2004 Scrambler 500, Various Others.
Etc is electronic throttle control. The contacts close and kill spark if the throttle gets stuck open and you let off the lever so it doesn’t run away on you.
ETC switch wires have been pulled off from connectorboard. Does it still kill the spark
Discussion Starter · #7 ·
Yes. Its wiring is not connected to controlboard. Does it still kill the spark
With the wires disconnected it does not kill the spark, but the handlebar switch, key switch and reverse speed limiter may still kill the spark
