1 - 8 of 8 Posts
My starter makes weird noises so I am looking to get a new one and when I go onto Amazon I search up the part number and it says fits 570 Sportsman does anyone know good starters not Polaris branded?
1995 magnum 425 4x4 2019 sportsman 570 2020 sportsman 850
Have you searched eBay? I got a new Chinese starter from eBay for my 850 in July. If you end up buying a China starter, make sure you get the extended warranty because mine only lasted a little over 3 months. The starter was $75 and the warranty was $10.
Arrowhead has one for $175, but Rick's does not list one
The part number for the 18 450 is 4014909, but part number 4014290 was superseded to 4014909 and either will work on the following models:
ASSEMBLIES WHERE 4014290 IS USED
2014 RANGER 570 INTL (R14RH57FX) - Engine, Starter Drive
2014 RZR 570 (Z14VH57AD/6EAI/6EAW) - Engine, Starter Drive
2015 RANGER 570 EFI FULL SIZE CREW (R15RUA57AA/E57AC) - Engine, Starter Drive
2015 570 EFI/EPS FOREST TRACTOR (A15SET57CA/S57CJ/CA) - Engine, Starter Drive
2015 RANGER 570 (R15RMA57AA/AR/AZ/AC/LA/H57AR) - Engine, Starter Drive
2015 RANGER 570 (R15RMA57FA) - Engine, Starter Drive
2015 RANGER 570 EFI CREW (R15RNA57AA/AC/AR/E57AS) - Engine, Starter Drive
2015 RANGER 570 FULL SIZE (R15RTA57AA/AR/AC/EAU) - Engine, Starter Drive
2015 RANGER 570 FULL SIZE (R15RTA57AA/BA/AR/AC/EAU) - Engine, Starter Drive
2015 SPORTSMAN 570 EFI (A15SEA57AA/AC/AD/LD) - Engine, Starter Drive
2015 SPORTSMAN 570 EFI EPS (A15SEE57AA/AC/AJ) - Engine, Starter Drive
2015 SPORTSMAN 570 EFI EPS FOREST QUAD (A15SEB57CA/CJ/SEC57CJ/CA) - Engine, Starter Drive
2015 SPORTSMAN 570 EFI MD (A15SEA57HA) - Engine, Starter Drive
2015 SPORTSMAN 570 EFI TOURING EU (A15SDA57FH) - Engine, Starter Drive
2015 SPORTSMAN 570 EFI UTE HD (A15SUH57AH) - Engine, Starter Drive
2015 SPORTSMAN 570 EFI X2 EPS (A15SWE57AA/AD) - Engine, Starter Drive
2015 SPORTSMAN 570 EFI X2 EPS EUROPE (A15SWE57FA) - Engine, Starter Drive
2015 SPORTSMAN 570 HD (A15SEH57AD) - Engine, Starter Drive
2015 SPORTSMAN 570 SP (A15SHD57AC/E57AS/AM/L57AK) - Engine, Starter Drive
2015 SPORTSMAN 570 SP TOURING (A15SJE57AS/AV) - Engine, Starter Drive
2015 SPORTSMAN TOURING 570 EFI/EPS (A15SDA57AA/LJ/E57AJ) - Engine, Starter Drive
2016 ACE 570 EFI (A16DAA57A5/A7/L2/E57A9/E57AM) - Engine, Starter Drive
2016 ACE 570 EFI EURO (A16DAA57F1/F2/E57FM) - Engine, Starter Drive
2016 ACE 570 EFI HD (A16DAH57A1) - Engine, Starter Drive
2016 ACE 570 EFI MD (A16DAA57N1/E57NM) - Engine, Starter Drive
2016 RANGER 570 (R16RMA57A1/A4/A9/L1/E57AS/A9/H57AR) - Engine, Starter Drive R16rma57a1/A4/A9/L1/E57as/Ea9/Har
2016 RANGER 570 EFI CREW (R16RNA57A1/A9/A4/EAH) - Engine, Starter Drive R16rna57a1/A9/A4/E57ah
2016 RANGER 570 EU (R16RMA57F1/N1/EFH/SF1/2N1) - Engine, Starter Drive
2016 RANGER 570 FULL SIZE (R16RTA57A1/A4/A9/B1/B4/B9/EAP/EBP) - Engine, Starter Drive
2016 RANGER 570, 570 XP, FULL SIZE CREW (R16RVA57A1/B1/E57A9/B9) - Engine, Starter Drive
2016 RANGER 570, FULL SIZE (R16RCA57A1/A4/B1/B4) - Engine, Starter Drive
2016 RANGER 570-6, FULL SIZE CREW (R16RDA57A1/B1) - Engine, Starter Drive
2016 SPORTSMAN 570 EFI (A16SEA57A1/3/7/8/9/L3/L7/L8/E57A1/3/5/7/9/D57A2) - Engine, Starter Drive
2016 SPORTSMAN 570 EFI (A16SEA57A1/7/8/9/E57A1/2/5/7/9) - Engine, Starter Drive A16sea57a1/7/8/9/L7/E57a1/5/7/9
2016 SPORTSMAN 570 EFI (A16SEA57A1/7/8/9/L7/E57A1/5/7/9) - Engine, Starter Drive
2016 SPORTSMAN 570 EFI HD (A16SEH57A7) - Engine, Starter Drive
2016 SPORTSMAN 570 EFI X2 EPS (A16SWE57A1/A7) - Engine, Starter Drive
2016 SPORTSMAN 570 SP (A16SHD57A9/AR/E57AS/AM) - Engine, Starter Drive
2016 SPORTSMAN 570 SP (A16SHD57A9/E57AS/AM) - Engine, Starter Drive
2016 SPORTSMAN 570 SP TOURING (A16SJE57AB) - Engine, Starter Drive
2016 SPORTSMAN 570/450 EPS QUAD (A16SEB57C1/C2/SEC57C1/C2/SBB57C1) - Engine, Starter Drive
2016 SPORTSMAN TOURING 570 EFI/EPS (A16SDA57A1/L2/E57A2) - Engine, Starter Drive
2017 450 FARMHAND HD 2X4 (A17SAH50A5) - Engine, Starter Drive
2017 570 SPORTSMAN 6X6 (A17S6E57A1) - Engine, Starter Drive
2017 ACE 500 SOHC (A17DAA50A7) - Engine, Starter Drive
2017 R17RM250A1 RANGER 500 2WD HDPE (R17RMA50A4/250A1) - Engine, Starter Drive R17rm250a1
2017 RANGER 499, ETX, HDPE (R17RMA50A4) - Engine, Starter Drive
2017 RANGER 500 2WD HDPE (R17RM250A1) - Engine, Starter Drive
2017 RANGER 500, ETX, HDPE (R17RMA50A4/A1) - Engine, Starter Drive
2017 RANGER 570 (R17RMA57A1/A9/E57AK) - Engine, Starter Drive
2017 RANGER 570 EFI CREW (R17RNA57A1/A9/EAM) - Engine, Starter Drive
2017 RANGER 570 EFI CREW (R17RNA57A1/A9/EAM/ENM) - Engine, Starter Drive R17rna57a1/A9/Eam/Nm
2017 RANGER 570 EFI CREW (R17RNA57A1/A9/EAM/NM) - Engine, Starter Drive
2017 RANGER 570 EPS HDPE (R17RMH57A4) - Engine, Starter Drive
2017 RANGER 570 EPS, HDPS, EU, ZUG, POLAND (R17RME57F1/S57C1/CK/E1/EK/F1/T57C1/E1/A57F1) - Engine, Starter Drive R17rme57f1/S57c1/F1/Ck/E1/Ek/T57c1/E1/A57f1
2017 RANGER 570 MD (R17RMA57N1) - Engine, Starter Drive
2017 RANGER 570, FULL SIZE (R17RCA57A1/A4) - Engine, Starter Drive
2017 RANGER 570, FULL SIZE (R17RCA57A1/B1/A4/B4) - Engine, Starter Drive
2017 RANGER CREW 570FS (R17RDA57A1/B1) - Engine, Starter Drive
2017 RZR 570 (Z17VHA57A2/E57AU) - Engine, Starter Drive
2017 RZR 570 EU (Z17VHA57FJ) - Engine, Starter Drive
2017 RZR 570 S (Z17VJE57AR) - Engine, Starter Drive
2017 SPORTSMAN 450 HO (A17SEA50A1/A5/SEE50A1/SEG50A4) - Engine, Starter Drive
2017 SPORTSMAN 570 EFI (A17SEA57A1/5/7/9/L7/L8/E57A1/7/9/F57A4) - Engine, Starter Drive
2017 SPORTSMAN 570 EFI (A17SEA57A1/7/8/9/L7/L8/E57A1/7/9/F57A4) - Engine, Starter Drive A17sea57a1/7/9/L7/L8/E57a1/7/9/F57a4
2017 SPORTSMAN 570 EFI (A17SEA57A1/7/9/L7/L8/E57A1/7/9/F57A4) - Engine, Starter Drive
2017 SPORTSMAN 570 EFI HD (A17SEH57A7) - Engine, Starter Drive
2017 SPORTSMAN 570 EFI X2 EPS (A17SWE57A1) - Engine, Starter Drive
2017 SPORTSMAN 570 SP (A17SHD57A9/AG/E57AS/E57AL) - Engine, Starter Drive
2017 SPORTSMAN 570 SP TOURING (A17SJE57AU) - Engine, Starter Drive
2017 SPORTSMAN TOURING 570 EFI/EPS (A17SDA57A1/E57A2/E57L2) - Engine, Starter Drive A17sda57a1/L2/E57a2
2017 SPORTSMAN TOURING 570 EFI/EPS (A17SDA57A1/L2/E57A2) - Engine, Starter Drive
2018 450 SPORTSMAN HD 2X4 (A18SAA50N5) - Engine, Starter Drive
2018 570 SPORTSMAN 6X6 (A18S6E57B1) - Engine, Starter Drive
2018 ACE 500 SOHC (A18DAA50B7) - Engine, Starter Drive
2018 R18RDA57A1/B1 RANGER CREW 570 FS R18RDA57A1/B1 (R04.) - Engine, Starter Drive R18rda57a1/B1
2018 R18RMA50B4/B1 RANGER 500, HDPE ((R18RMA50B4/B1) - Engine, Starter Drive R18rma50b4/B1
2018 RANGER 500 2WD HDPE (R18RM250B1) - Engine, Starter Drive
2018 RANGER 570 (R18RMA57B1/B9/E57BV/N4) - Engine, Starter Drive
2018 RANGER 570 (R18RMA57B1/B9/L1/E57BV/N4) - Engine, Starter Drive
2018 RANGER 570 CREW (R18RNA57B1/B9/EBV) - Engine, Starter Drive
2018 RANGER 570 EPS CREW MD (R18RNE57NV) - Engine, Starter Drive
2018 RANGER 570 EPS, HDPS, EU, POLAND (R18RMA57F1/S57C1/F1/CV/T57C1) - Engine, Starter Drive
2018 RANGER 570, FULL SIZE (R18RCA57A1/A4/B4/B1) - Engine, Starter Drive
2018 RANGER CREW 570 FS (R18RDA57A1/B1) - Engine, Starter Drive
2018 RZR 570 (Z18VHA57B2) - Engine, Starter Drive
2018 RZR 570 EU (Z18VHA57F2) - Engine, Starter Drive
2018 RZR 570 PS (Z18VHE57BV) - Engine, Starter Drive
2018 SPORTSMAN 450 HO (A18SEA50B1/B5/SEE50B5/B8/SEG50B8) - Engine, Starter Drive
2018 SPORTSMAN 450 HO (A18SEA50B1/B5/SEE50B5/SEG50B8) - Engine, Starter Drive
2018 SPORTSMAN 570 EFI (A18SEA57B1/7/9/L2/L5/L7/E57B1/7/9/BK/F57B8) - Engine, Starter Drive
2018 SPORTSMAN 570 EFI (A18SEA57B1/7/9/L2/L5/L7/E57B1/7/9/F57B8) - Engine, Starter Drive
2018 SPORTSMAN 570 EFI X2 EPS (A18SWE57B1) - Engine, Starter Drive
2018 SPORTSMAN 570 SP (A18SHD57B9/E57BB/E57BS) - Engine, Starter Drive
2018 SPORTSMAN 570 SP TOURING (A18SJE57BU) - Engine, Starter Drive
2018 SPORTSMAN 570 SP TOURING (A18SJE57BU/LU) - Engine, Starter Drive
2018 SPORTSMAN TOURING 570 EFI/EPS (A18SDA57B7/L7/E57B5) - Engine, Starter Drive
2018 SPORTSMAN TOURING 570 EFI/EPS (A18SDA57B7/L7/E57B5/D57LU) - Engine, Starter Drive
2019 ACE 500 SOHC (A19DBA50A5) - Engine, Starter Drive
2019 RANGER 500 (R19RMA50B4/B1) - Engine, Starter Drive
2019 RANGER 500 2WD HDPE (R19RM250B1) - Engine, Starter Drive
2019 RANGER 570 (R19RMA57B1/B9/EBX) - Engine, Starter Drive
2019 RANGER 570 (R19RMA57B1/B9/L7/EBX) - Engine, Starter Drive
2019 RANGER 570 CREW (R19RNA57B1/B9/EBX) - Engine, Starter Drive
2019 RANGER 570 EPS HD (R19RME57D7) - Engine, Starter Drive
2019 RANGER 570 EPS, EU, POLAND (R19RMA57F1/S57C1/F1) - Engine, Starter Drive
2019 RANGER 570, FULL SIZE (R19RCA57A1/A4) - Engine, Starter Drive
2019 RANGER 570, FULL SIZE (R19RCA57A1/A4/B1/B4) - Engine, Starter Drive
2019 RANGER CREW 570 FS (R19RDA57A1) - Engine, Starter Drive /B1
2019 RANGER CREW 570 FS (R19RDA57A1/B1) - Engine, Starter Drive
2019 RZR 570 (Z19VHA57B2/E57BM) - Engine, Starter Drive
2019 RZR 570 EU MD (Z19VHA57F2) - Engine, Starter Drive
2019 SPORTSMAN 450 HD 2X4 (A19SAA50D5) - Engine, Starter Drive
2019 SPORTSMAN 450 HO (A19SEA50B1/B7/SEE50B7/B3/SEG50B4) - Engine, Starter Drive
2019 SPORTSMAN 450 HO (A19SEA50B1/B7/SEE50B7/SEG50B4) - Engine, Starter Drive
2019 SPORTSMAN 570 6X6 (A19S6E57B1) - Engine, Starter Drive
2019 SPORTSMAN 570 EFI (A19SEA57B1/5/9/L2/L7/E57B1/5/9/F57B4/SEY57B5) - Engine, Starter Drive
2019 SPORTSMAN 570 EFI (A19SEA57B1/5/9/L2/L7/E57B1/5/9/F57B4/SEY57B5/SEZ57BZ) - Engine, Starter Drive
2019 SPORTSMAN 570 EFI (A19SEA57B1/5/9/L2/L7/E57B1/5/9/FB4/YB5/ZBZ) - Engine, Starter Drive A19sea57b1/5/9/L2/L7/E57b1/5/9/F57b4/Sey57b5/Sez57bz
2019 SPORTSMAN 570 EFI X2 EPS (A19SWE57B1) - Engine, Starter Drive
2019 SPORTSMAN 570 SP (A19SHD57B9/E57BJ/E57BW) - Engine, Starter Drive
2019 SPORTSMAN 570 SP TOURING (A19SJE57BH) - Engine, Starter Drive
2019 SPORTSMAN TOURING 570 EFI/EPS (A19SDA57B7/L7/SDD57LU/SDE57B5) - Engine, Starter Drive
2020 RANGER 500 (R20MAA50B1/B7) - Engine, Starter Drive
2020 RANGER 570 (R20MAA57B1/B9/EBH) - Engine, Starter Drive
2020 RANGER 570 (R20MAA57B1/B9/LH/EBH) - Engine, Starter Drive R20maa57b1/B9/L7/Ebh
2020 RANGER 570 CREW (R20M4A57B1/B9/EBH) - Engine, Starter Drive
2020 RANGER 570 CREW FULL SIZE (R20CDA57A1/B1) - Engine, Starter Drive
2020 RANGER 570 CREW LTN (R20M4A57L1) - Engine, Starter Drive
2020 RANGER 570 LTN (R20MAA57L7) - Engine, Starter Drive
2020 RANGER 570, FULL SIZE (R20CCA57A1/A7) - Engine, Starter Drive
2020 RANGER 570, FULL SIZE (R20CCA57A1/A7/B1/B7) - Engine, Starter Drive
2020 RANGER CREW 570 FULL SIZE (R20CDA57A1) - Engine, Starter Drive
2020 RZR 570 (Z20CHA57A2/E57AM) - Engine, Starter Drive
2020 SPORTSMAN 450 HO (A20SEA50A1/A5/CA1/CA5/E50A1/CA1/CA5) - Engine, Starter Drive
2020 SPORTSMAN 450 HO EPS (A20SEE50A5) - Engine, Starter Drive
2020 SPORTSMAN 450 HO UTL (A20SEG50A1/A5/CA1/CA5) - Engine, Starter Drive
2020 SPORTSMAN 570 6X6 (A20S6E57A1) - Engine, Starter Drive
2020 SPORTSMAN 570 EFI (A20SEA57A1/A4/A7/A9/B1/B4/B7/B9) - Engine, Starter Drive
2020 SPORTSMAN 570 EFI X2 EPS (A20SWE57A1/3A1) - Engine, Starter Drive
2020 SPORTSMAN 570 EPS (A20SEE57A1/A4/A7/A9/B1/B4/B7/B9) - Engine, Starter Drive
2020 SPORTSMAN 570 EPS UTILITY (A20SEJ57A1/A4/A7/A9) - Engine, Starter Drive
2020 SPORTSMAN 570 EPS UTILITY (A20SEJ57A1/A4/A7/A9/B1/B4/B7/B9) - Engine, Starter Drive
2020 SPORTSMAN 570 LATIN (A20SEA57L6/L7) - Engine, Starter Drive
2020 SPORTSMAN 570 PREMIUM (A20SHE57AN/AF/BN/BF) - Engine, Starter Drive
2020 SPORTSMAN 570 SP (A20SHD57A9) - Engine, Starter Drive
2020 SPORTSMAN 570 SP TOURING (A20SJE57AX/BX) - Engine, Starter Drive
2020 SPORTSMAN 570 UTL (A20SEG57A1/A4/A7/A9/B1/B4) - Engine, Starter Drive
2020 SPORTSMAN TOURING 570 EFI/EPS (A20SDA57A5/L4/E57A4/B4/LE) - Engine, Starter Drive
Avoid the Chinese garbage at all costs - you do not have a recoil starter, nor can it be push started.
Buy a quality starter, you get what you pay for.
1 - 8 of 8 Posts
