1 - 1 of 1 Posts
Ok, new to the forum and trying to figure out an issue with my kids quad. When the rear brake is engaged it locks the brake but then will not release until you pry the cable attachment. Just looking for some advice on if the entire rear brake needs to be replaced or if there is an adjustment. I messed with the adjustment screw bit once it is engaged the brake is locked and it won’t release with pressure from spring. Any help is much appreciated.
1 - 1 of 1 Posts
