When starting out riding the ATV runs fine. But once the machine starts to heat up its starts to bog out and backfire abit. As soon as you stop it will shut itself off. Going about 35 km/h with the engine at 4200 rpm will drop down to about 3780 rpm then will come back up to 4200 rpm roughly. As soon as you stop it drops from 1300 rpm right to 90 rpm then dead. If anyone has had this issue and has fixed it that would be a great help thanks!
New air filter has been put on K/N with bag
New fuel filter
Noticed a line was starting to rub through on a brake line but not terrible where there ijs a hole
any codes??
double verify your results they dont sound correct.
