my magnum 500 has been quiting when put in reverse. i herd ths is typical for thease machines. and i have another post about lack of power. yesterday i was riding and it is working great full speed again no stalling when shifterd into reverse. i was in some mud and got hung up. now when i pout it in reverse i dont have to push the override to get full throttle BUT now even with the override pused I have no 4X4. aneyone have this problem?
I would start with the basics, make sure you have power to your switch. AWD should light up. If you have power there, you can ohm the coils should be around 25 on each side, just to be sure the coil wires didn't get tore. let me know if that cures it.
Discussion Starter · #4 ·
so far it all checks out ok. power to switch and to the coils in forward but not reverse obviously . also I noticed the reverse light is not working. checked it and no power to it when in reverse.
