Polaris 500 Sportsman won’t turn over
663 Views 6 Replies 5 Participants Last post by  konehead
This has got me stumped. I changed the cam and adjusted the valves. But when I try to start it the starter turns over a couple of times then stops. If I take the plug out it cranks just fine. I can also get it to turn over by using the pull starter. I have replaced the starter but that didn’t help. Anyone got any ideas
Font Line Window Pattern Screenshot
to the forum
Ball Gas Font Vehicle registration plate Automotive lighting
See less See more
2
Compression release assy?
Reactions: 1
Was the piston at TDC when the cam was timed?
It was the compression release. A little hard getting more tension on the spring but it turns over just fine now. Hopefully I can get it to start. I guess I now wave a spare starter. Thanks to all that replied
Reactions: 1
Your timing is off
