No power at all when key is turned on. New batt. Had it checked, power to all systems, but no power out of the two contol modules. Will not even crank.
Look for broken wires in harness around steering stem , have to remove front plastic, then get wires out of harness to inspect them.
Welcome to the board.
Not sure if they still had those "pods" or pouches with circuit breakers in them. may have corroded breaker not making connection. When you jump the solenoid does it crank?
