what can i check that can cause the exhaust heating bright red, causing the gaz tank to bild up allot of pressure ive put some exhaust wrap and didnt help what can i do to know whats appenning?????
Check your coolant level to make sure it's not low. Make sure your fan is coming on to.
I have an '03 700 that does the same thing. I think that it may be normal, at least on the 700 twin.
Not sure about the 570, but the 700 is a twin cylinder. That is a lot of heat that goes from 2 into 1 almost immediately, then an abrupt !80 degree turn backwards in a very small, fairly thin pipe. But that is only my opinion.
To help cool the pipe down I made a little modification that works fairly well. I took the largest computer heat sink i had and secured it as tightly as possible so it don't rattle. Position the heat sink right on the the 180 degree bend touching as much real estate as possible, making sure fins are oriented correctly.
Troll much?
Only a parrot would ask she same question over & over again less a troll.
Remembered you from the multiple threads asking the same thing.
Here is what a quick search of your threads has brought up.
Read your threads
Search took 0.07 seconds.
Search: Keyword(s): ; Posts Made By: gab570
Forum: ATV Repair and Maintenance
* 05-14-2017, 10:03 AM
* Polaris 570 2015 pressure in gas tank
Posted By gab570
Hi guys i needs some answers i have a 2015 pokaris 570 and there is a big pressure in the gas tank ive put some exhaust wrap on the exhaust and i only have to ride 10 minute and the pressure as...
Forum: Around The Garage
* 05-13-2017, 11:54 PM
* polaris 570 big pressure in fuel tank
Posted By gab570
Yes it is a valve
Yes it is a valve
* 05-13-2017, 11:52 PM
Posted By gab570
It's a 2015 Polaris sportsman 570 no modification...
It's a 2015 Polaris sportsman 570 no modification and it only as 3200 km on it always sleep in a garage and never been beaten
* 05-13-2017, 11:47 PM
Posted By gab570
So you meen that it's normal that I don't have to...
So you meen that it's normal that I don't have to do anything
Forum: ATV General Discussion
* 05-13-2017, 11:40 PM
* 2015 Polaris 570 vent question ???
Posted By gab570
If the vent is diffective can it be fix or I have to change the gas tank assembly???
Forum: Polaris Sportsman
* 05-13-2017, 09:02 PM
* polaris 570 2015 exhaut heating
Posted By gab570
* 05-13-2017, 08:48 PM
* exhaust heating on sportsman 570 2015
Posted By gab570
* 05-08-2017, 07:34 AM
Posted By gab570
For the exhaust heating
* 05-07-2017, 08:37 PM
Posted By gab570
Is there some recalls for that
* 05-06-2017, 10:51 PM
* 2015 Polaris 570 fuel tank pressure extremely high
Posted By gab570
Hi I want to know if you ever saw that trouble befor and what should I check and what should I do to fix that problem the dealer here could help me oping you can
* 05-06-2017, 09:43 PM
Posted By gab570
Is the vent a valve or not
* 05-06-2017, 09:05 PM
Posted By gab570
So if its only doing it went it hot its because...
So if its only doing it went it hot its because of the exhaust not the vent ??
* 05-06-2017, 07:57 PM
Posted By gab570
It only does it when its warm when the bike is...
It only does it when its warm when the bike is cold it runs good
* 05-06-2017, 09:13 AM
Posted By gab570
In built in the tank not on the cap
* 05-06-2017, 09:11 AM
Posted By gab570
Yes sorry im french and the bike is a 2015 570...
Yes sorry im french and the bike is a 2015 570 sportsman and i now the tank alway have a little pressure but that is a realy big pressure i have to remove the gaz cap with my 2 hands thats not normal
* 05-06-2017, 07:04 AM
Posted By gab570
I did it and it still does the same thing
* 05-06-2017, 06:35 AM
Posted By gab570
Non i tink the valve is mold in the tank im not...
Non i tink the valve is mold in the tank im not sure
* 05-06-2017, 05:18 AM
Posted By gab570
The pressure releave valve on the tank is good...
The pressure releave valve on the tank is good gaz is coming out of it
* 05-06-2017, 04:44 AM
Posted By gab570
But ma dad as tbe same bike and my oncles too but...
But ma dad as tbe same bike and my oncles too but they dont do it like mine, and if i dont open the gaz cap to make the pressure go away the fuel pemp will start to wind
* 05-05-2017, 09:28 PM
Posted By gab570
Ok so if its not there i should put the tape and...
Ok so if its not there i should put the tape and if its there that should not be the problem is that it ???
* 05-05-2017, 09:12 PM
Posted By gab570
So its my exhauts that does all the troble
* 05-05-2017, 07:43 PM
Posted By gab570
i feel like the bike is going to blow up
* 05-05-2017, 07:24 PM
Posted By gab570
i have a big pressure bilding in my fuel tank what could cause this problem? and what can i does to fix this problement? I went to the dealer for a winding in the fuel tank and they didnt found...
