Possable the Water pump impeller is spinning on the shaft??
Thanks did not think about bad impeller spinning on shaft. Will take cover off and check it.Passable the Water pump impeller is spinning on the shaft??
Was not a bad impeller. The impeller looks good and will not turn. So it is not the impeller.Possable the Water pump impeller is spinning on the shaft??
THe engine was hot but it did not appear boiling hot. I think it reached the high temperature but not to the point of blowing the water out. Now I have not put antifreeza and do not know if antifreeze coolant would make a difference in cooling capcity or not.Try replacing the radiator cap , you mentioned there was little pressure when you removed it ? It should have had pressure if engine was hot ?
