had to change transmissions
After putting everything back together
I have shifting problems
1, will shift from L to R but have to shut off engine to put in H or park
misses N when running
when in gear at engine idle the unit moves
do I have a clutch or belt problem???
need help
WELCOME!
Sounds like an alignment or engine mount or idle speed problem.
Any of these will cause problems shifting and creeping in gear. Two of them the engine mount and alignment are actually a alignment issue. See the belt MUST be square and true running thru the sheaves. If it drags on one side or the other it will spin the tranny and cause creeping and hard shifting. Since you had the tranny out, I'll about gaurenty you have it just a bit crooked.
