While cruising the local Craig's List ads..... I came across the following ad and wondered what some of you long time "Polaris ATV Guru's" believe could be wrong with this machine? I would like to see if it's a project I'd like to take on or if I should allow some other poor unsuspecting sucker pick up.
Ad Reads:
For Sale: 1994 Polaris Sportsman 400 4x4. This atv will start and run for a minute then die and not want to start again. 4x4 works. It has a good battery. Electric Start. Tires are 65-75 % tread. When I bought it, I was told it just recently had a new sleeve installed in the cylinder and a new std piston and rings. It is in pretty decent shape besides a crack in the plastic shroud that covers the fuel tank and a small crack in the rear plastic that isn't very visible. Chains And Sprockets Look Fine. No Odometer, I don't know the miles! I got it as a project, im selling it as a project. I have way too many projects.
They are asking $650 Cash.... but would hope it could be had for less, more like $400-500 depending on what is likely wrong with this machine.
Just starting to look for a machine to tinker on and have as a 3rd or spare for friends to use or for the son to grow into over the next few years.
Thanks for your thoughts and input....
Ad Reads:
