Hello. I have a 2012 sportsman 500 Ho and all the breaks are “closed “ Their not locked up, but the calipers aren’t releasing, their holding the pads onto the rotors. I would like to clean or rebuild these, because they’ve never been serviced. About 900 miles, most of which were put on this year. There’s plenty of videos online and I have a manual. My questions are: when you take the break line off, will the fluid completely empty out ? And should you replace all the brake fluid ? Not sure if there’s a specific order or any other advice. I’m assuming the master cylinder might need to be serviced. Thanks in advance
