here is how the clutches are set up, it looks like you are missing a few parts
1 5411553 SEAL,CLUTCH CVR,INNER 1 Usage
2 7555748 WASHER(10) (If built before 4/03/00) 3 Usage
3 7512278 BOLT(10) (If built before 4/03/00) 3 Usage
3 7517860 BOLT/RBR WASHER 1/4-20X1,ASM.(10) (If built after 4/03/00) 3 Usage
4 5521301 SEAL,CLUTCHCOVER 1 Usage
5 5433542 COVER-CLUTCH,FRONT,ST-801HS 1 Usage
6 7670051 CLIP,CLUTCH COVER(10) 1 Usage
7 7512093 SCREW(10) 5 Usage
8 7078689 DECAL,WARNING,CLUTCH CVR 1 Usage
9 7074782 DECAL,AUTO.TRANSMISSION 1 Usage
10 7512094 SCREW(10) 2 Usage
11 7080492 STRAP,BLK,WEATHER-RESIST.(10) 4 Usage
12 5410421 BOOT,CLUTCH INTAKE 1 Usage
13 7517916 SCR-1/4-20X3/4-TR/TX/TAP-M(10) 1 Usage
14 5432302 CLIP,OIL LINE RET.(10) 2 Usage
15 7080511 CLAMP, NARROW BAND(10) 1 Usage
16 7555783 WASHER(10) 1 Usage
17 7512018 SCREW(10) 1 Usage
18 5811373 FOIL-TAPE,AIR BOX 1 Usage
19 5433258 DUCT,CLUTCH INLET,TRAIL BOSS 1 Usage
20 5411822 BOOT,CLUTCH AIR INLET,UPPER 1 Usage
21 5433450 DUCT,CLUTCH INLET 1 Usage
22 7512084 SCREW(10) 1 Usage
23 7556091 SPACER 1 Usage
24 2200792 KIT,CVR,IN.CLUTCH (Incl. 4,7,10,29,32) 1 Usage
25 7555932 WASHER,NYLON 1 Usage
26 5242693-067 BRKT,CLUTCH COVER,BLK 1 Usage
27 7555935 WASHER(10) 1 Usage
28 5433323 DUCT,OUTLET,CLUTCH,13.57 1 Usage
29 5410749 SEAL,COVER CASE 1 Usage
30 5222877-067 BRKT,RETAINER SEAL 1 Usage
31 ------- Screw and Washer (See Crankcase and Cylinder Pg. C9, Ref. 23) 4 Usage
32 7512098 SCREW 1 Usage
33 7512232 BOLT(10) 2 Usage
34 7661638 RIVET,INTERLOCK,B(50) 2 Usage
35 5242208-067 BRKT,CLUTCH,LOW,BLK 1 Usage
36 7547076 NUT,HEXHD,M8 3
