Does anyone know if the Polaris Sportsman 450 and the 570 share the same ground cable wire specifically is one longer than the other?
I installed the Battery Relocation kit from Quad Logic and the ground wire is about 2" short from allowing me to mount the Terminal Block to the frame.
I have a 2017 450ho.
The ground cable for your unit is part number 4014936 - it was used on the following models:
2015 570 EFI/EPS FOREST TRACTOR (A15SET57CA/S57CJ/CA) - Electrical, Battery
2015 HAWKEYE 325 2X4 (A15SAA32EH) - Electrical, Battery
2015 SPORTSMAN 570 EFI (A15SEA57AA/AC/AD/LD) - Electrical, Battery
2015 SPORTSMAN 570 EFI EPS (A15SEE57AA/AC/AJ) - Electrical, Battery
2015 SPORTSMAN 570 EFI EPS FOREST QUAD (A15SEB57CA/CJ/SEC57CJ/CA) - Electrical, Battery
2015 SPORTSMAN 570 EFI EPS MD (A15SEE57HJ/HA) - Electrical, Battery
2015 SPORTSMAN 570 EFI MD (A15SEA57HA) - Electrical, Battery
2015 SPORTSMAN 570 HD (A15SEH57AD) - Electrical, Battery
2015 SPORTSMAN 570 SP (A15SHD57AC/E57AS/AM/L57AK) - Electrical, Battery
2015 SPORTSMAN 570 SP EPS, QUAD (A15SHC57CS) - Electrical, Battery
2015 SPORTSMAN 570 SP EPS, TRACTOR (A15SHS57CS) - Electrical, Battery
2015 SPORTSMAN 570 SP MD (A15SHE57HS) - Electrical, Battery
2015 SPORTSMAN ETX EFI (A15SEA32AA/AH) - Electrical, Battery
2015 SPORTSMAN ETX EFI MD (A15SEA32HA) - Electrical, Battery
2015 SPORTSMAN TOURING 570 EFI/EPS (A15SDA57AA/LJ/E57AJ) - Electrical, Battery
2016 450 HO 2X4 MD (A16SAA57N1) - Electrical, Battery
2016 SPORTSMAN 450 HO (A16SEA45A1/A5/SEE45A1) - Electrical, Battery
2016 SPORTSMAN 570 EFI (A16SEA57A1/3/7/8/9/L3/L7/L8/E57A1/3/5/7/9/D57A2) - Electrical, Battery
2016 SPORTSMAN 570 EFI (A16SEA57A1/7/8/9/E57A1/2/5/7/9) - Electrical, Battery A16sea57a1/7/8/9/L7/E57a1/5/7/9
2016 SPORTSMAN 570 EFI (A16SEA57A1/7/8/9/L7/E57A1/5/7/9) - Electrical, Battery
2016 SPORTSMAN 570 EFI HD (A16SEH57A7) - Electrical, Battery
2016 SPORTSMAN 570 SP (A16SHD57A9/AR/E57AS/AM) - Electrical, Battery
2016 SPORTSMAN 570 SP (A16SHD57A9/E57AS/AM) - Electrical, Battery
2016 SPORTSMAN 570 SP EPS, QUAD (A16SHC57CM) - Electrical, Battery
2016 SPORTSMAN 570 SP EPS, TRACTOR (A16SHS57CM) - Electrical, Battery
2016 SPORTSMAN 570 SP MD (A16SHE57NM) - Electrical, Battery
2016 SPORTSMAN 570/450 EFI MD (A16SEA57N1/N7/E57N1/E57N2/BA57N1) - Electrical, Battery
2016 SPORTSMAN 570/450 EPS QUAD (A16SEB57C1/C2/SEC57C1/C2/CL/SBB57C1) - Electrical, Battery
2016 SPORTSMAN 570/450 EPS QUAD (A16SEB57C1/C2/SEC57C1/C2/SBB57C1) - Electrical, Battery
2016 SPORTSMAN 570/450 EPS ZUG (A16SES57F1/F2/SBT57F1) - Electrical, Battery
2016 SPORTSMAN 570/450 TRACTOR (A16SET57C1/C7/SES57C1/C2/SBT57C1) - Electrical, Battery
2017 450 FARMHAND HD 2X4 (A17SAH50A5) - Electrical, Battery
2017 SPORTSMAN 450 HO (A17SEA50A1/A5/SEE50A1/SEG50A4) - Electrical, Battery
2017 SPORTSMAN 570 EFI (A17SEA57A1/5/7/9/L7/L8/E57A1/7/9/F57A4) - Electrical, Battery
2017 SPORTSMAN 570 EFI (A17SEA57A1/7/8/9/L7/L8/E57A1/7/9/F57A4) - Electrical, Battery A17sea57a1/7/9/L7/L8/E57a1/7/9/F57a4
2017 SPORTSMAN 570 EFI (A17SEA57A1/7/9/L7/L8/E57A1/7/9/F57A4) - Electrical, Battery
2017 SPORTSMAN 570 EFI HD (A17SEH57A7) - Electrical, Battery
2017 SPORTSMAN 570 EPS EU (A17SEA57F1/SEE57F1/F2/FL) - Electrical, Battery
2017 SPORTSMAN 570 EPS ZUG (A17SES57F1/F2/FL/SET57F1) - Electrical, Battery
2017 SPORTSMAN 570 SP (A17SHD57A9/AG/E57AS/E57AL) - Electrical, Battery
2017 SPORTSMAN 570 TRACTOR (A17SES57C1/C2/C7/CL/E1/E2/E7/EL/SET57C1/C2/E1/E2) - Electrical, Battery
2017 SPORTSMAN 570/450 EFI MD (A17SEA57N1/EE57N1/NL) - Electrical, Battery
2017 SPORTSMAN TOURING 570 EFI/EPS (A17SDA57A1/E57A2/E57L2) - Electrical, Battery A17sda57a1/L2/E57a2
2018 450 SPORTSMAN HD 2X4 (A18SAA50N5) - Electrical, Battery
2018 SPORTSMAN 450 HO (A18SEA50B1/B5/SEE50B5/B8/SEG50B8) - Electrical, Battery
2018 SPORTSMAN 450 HO (A18SEA50B1/B5/SEE50B5/SEG50B8) - Electrical, Battery
2018 SPORTSMAN 570 EFI (A18SEA57B1/7/9/L2/L5/L7/E57B1/7/9/BK/F57B8) - Electrical, Battery
2018 SPORTSMAN 570 EFI (A18SEA57B1/7/9/L2/L5/L7/E57B1/7/9/F57B8) - Electrical, Battery
2018 SPORTSMAN 570 EFI HD (A18SEF57N5) - Electrical, Battery
2018 SPORTSMAN 570 EPS EU (A18SEA57F1/SEE57F1/7) - Electrical, Battery
2018 SPORTSMAN 570 EPS EU SP (A18SHE57FS) - Electrical, Battery
2018 SPORTSMAN 570 EPS TRACTOR (A18SES57C1/C2/C5/C7/E1/E5/E7/P57C1/T57C1/C7/E1/E7) - Electrical, Battery
2018 SPORTSMAN 570 EPS TRACTOR (A18SES57C1/C2/C5/C7/E1/E5/E7/T57C1/C7/E1/E7) - Electrical, Battery
2018 SPORTSMAN 570 EPS TRACTOR SP (A18SHS57CS/ES) - Electrical, Battery
2018 SPORTSMAN 570 EPS ZUG (A18SES57F1/F7/SET57F1) - Electrical, Battery
2018 SPORTSMAN 570 EPS ZUG SP (A18SHS57FS) - Electrical, Battery
2018 SPORTSMAN 570 SP (A18SHD57B9/E57BB/E57BS) - Electrical, Battery
2019 SPORTSMAN 450 HD 2X4 (A19SAA50D5) - Electrical, Battery
2019 SPORTSMAN 450 HO (A19SEA50B1/B7/SEE50B7/SEG50B4) - Electrical, Battery
2019 SPORTSMAN 570 EFI (A19SEA57B1/5/9/L2/L7/E57B1/5/9/F57B4/SEY57B5) - Electrical, Battery
2019 SPORTSMAN 570 EPS EUN (A19SEA57R1/SEE57R1/7) - Electrical, Battery
2019 SPORTSMAN 570 EPS EUN SP (A19SHE57RS) - Electrical, Battery
2019 SPORTSMAN 570 EPS TRACTOR (A19SEP57P1/SES57P5/7/SET57P1/7) - Electrical, Battery
2019 SPORTSMAN 570 EPS TRACTOR SP (A19SHS57PS) - Electrical, Battery
2019 SPORTSMAN 570 EPS ZUG SP (A19SHS57RS) - Electrical, Battery
2019 SPORTSMAN 570 EPS ZUGN (A19SES57R1/7/SET57R1) - Electrical, Battery
2019 SPORTSMAN 570 SP (A19SHD57B9/E57BJ/E57BW) - Electrical, Battery
2019 SPORTSMAN 570 UTIL HD (A19SEF57D5) - Electrical, Battery
Either make/purchase the proper length cable or bolt both cables to the frame and call it a day.
Thank you for the valuable information with all those models being the the same cable I decided to give it another go. It will fit a tight fit but it did fit thank you much. All is needed to do now is wire ties.
