Hi. I have here a brand new polaris sportsman thumb warmer switch. It is a polaris part number: 4010964. This will also work as a hand warmer switch, revese (back up/work lights to) the only differance from the hand to the tumb warmer switch is the logo on top, and the only differnace between the hand/tumb warmer switch and the work light switch is an extra pin. This way you can add something else. But you wont be able to control both things at once.
Characteristics
ratings: 10.1 amps at 125vac resistance
electrical life: 25,000 cycles
mechanical
mechanical life: 100,000 cycles
physical
base material: Thermoplastic
button material: Black thermoplastic
case material: Black thermoplastic
terminal material: Brass alloy
mounting hole
panel thickness .025min .187 max.
Hole size
1.072 x .480
retail price: $32.18+tax at a local polaris dealer
let me know. I have 2. But can get more..
Pic will be added later. But it is the black rectangel ones that fit in the stock holes in the head light pod on the 05' and newer ones.
Discussion Starter · #3 · (Edited)
yup i have a few.
heres one for now i will load more on mon. i have one thumb and one hand icon warmer switch
thought id also add a pic of my switches compleated:
