1 - 14 of 14 Posts
man, there on youtube, it doesn't help at all for most because he points at problems under the machines and doesn't move the camera.
Ohh, the eVillage videos ??? Ya, I like the idea, but as has already been mentioned, I REALLY wish he would move the camera, rather than say 'Here's the drain plug location' by pointing at something that only he can see.
Coming from a Warrior, I was very surprised to find that there were so few Polaris 'How-To' videos available on Youtube, but there were dozens for my Warrior. I never needed a manual in fact, I could just find a video on the 'Tube that detailed whatever I needed done to it.
The Polaris scares me with its complexity, so I am certain I will need to invest in a Clymers manual at some point.
i'm trying to get rear cvshafts out on my 05 sportsman 500HO and nothing is working the shaft wont come out of the tranny so i tried to take the other side out and it wont come out either
.....Coming from a Warrior, I was very surprised to find that there were so few Polaris 'How-To' videos available on Youtube, but there were dozens for my Warrior.
Tell me about it!!!! We have a '94 400 Xplorer that we need to pull the clutch on so that we can get the starter off and I can't find a single video or how-to description so that we don't screw anything up pulling the clutch. We have a clutch puller, just need the specifics... I did post on here a dedicated thread asking for info from anyone who may know.... UGH
:hmmm:
:hmmm:
i needs to do the starter on mine also. maybe ill make a video and stick it up. (would not be till mid next week)
There is a 9/16 nut that holds the yoke of the drive shaft to the tranny. You can only get a open wrench in there. My problem is the nut seams to turn on a stud (turh left nut right nut turns also) I can not find a exploded image to see what is what. Hate to have that stud?? come all the way out.
was just working on my sportsman doing cv axle. i ended up using a tie rod pitchfork between cup and case. couple hard whacks with a dead blow and the axle started popping out, finished with a small pry bar. problem I'm having is getting the new one in! pain in the you know what!!!
I bought 2 different manuals for mine. Do the same. They both have the info but each has what the other leaves out.
help
can you email me how to check the timing marks no one up here in georgia knows any thing about the diesel motor and i hat to scrap a good looking atv like this one my email is [email protected] i sure do need your help if you have time ...thanks
:hmmm:
did you end up changing the starter? I have a 95 xplorer 400 2 stroke and need to change my starter
Help with Video
Is there a video that you know of that may help me figure out how to check the timing on my 2007 Hawkeye ? I removed my cam chain tensioner "by mistake" an am afraid to reinstall the tensioner without checking the timing ?
Can anyone help ? Thank you in advance/
1 - 14 of 14 Posts
