First let me apologize for being so ignorant when it come to wiring.
I just installed the kokusan ignition upgrade on my 03 sportsman 700.
Problem 1
I have one extra red wire that runs along with the black wire that runs to the kill switch. Can not find anywhere to connect it. I assumed it was extra. But not so
sure now.
Problem 2
When I connect the brown ground wire the atv tries to start with the headlight switch. ???? Found this out by accident. I believe it is the same brown ground harness wire I connected with the stator.
Instructions on wiring are sketchy at best. Got my answer from old polaris tech yesterday morning. Problem resolved. Any one else having this issue there is a red wire buried in the electrical harness. I had to open mine up to find it. I also missed a ground wire that was causing it to try and start with the lights. Double check all your connections. I thought I had mine right but that was not the case. It is running great with the new upgrade.
