2021 outlaw 110 changed fuel pump, ecu, and wire harness. Cleaned fuel injector and will not run. Has spark, will run on stator fluid. I am at a loss on what there is left to get this thing running. Help would be appreciated.
if it runs on starter fluid it should be a fuel issue, by that i mean its not getting any did you test the fuel pressure on the new pump? and make sure it is all plugged in and no loose wires
is the airbox and filter in place when trying to start it? i still think its not getting enough fuel, if it runs on starter fluid maybe something with the ecu not triggering the injector long enough
have you checked the spark plug to see if its fouled
Tried every scenario and configuration, New plug. I read a post from here somewhere from back in April and responded to that post but no response. So I started a new thread.
