I have a 2018 pheonix with only 20 hrs and it makes a squealing noise and stops pulling whenever going up a steep hill which is very dangerous for my son. With that said now the quad will barley move at full throttle. Bought it used so no warranty.
has anyone had this problem before I spend the money to replace both clutch drives?
any help here would be appreciated.
Best guess - the variator needs serviced and it needs a new belt - might need the driven clutch serviced also - the driven clutch is a centrifugal clutch an it might be due for new friction shoes.
Thanks latebird belt is good lots of dust after removing cover I’m going to pull both off and inspect
