I have engine code 22 on my 2008 Polaris Ranger 700 xp 4x4 TPS open or short circuit to ground and TPS short circuit your battery what does that mean ty
Sounds like you probably have some wires in the TPS harness bad. It can be external (obvious) or internal (not so obvious). Could also be internal to the TPS itself. Takes some special tools, knowledge and info to check/replace the TPS. If you don't have them you may be time and money ahead to make an appointment with your dealer.
