Can anyone tell if this little piece goes into that hole in the gearcase ?
I'm replacing a broken swingarm and I can't remember from where that little guy fell off... thanks in advance
137454
137451
137452
I think is the number 36... I'm seeking help because I've never done it.
In theory I put that bushing/pivot inside that hole in the gearcase, then put the left side of the swingarm in place, screw the big swingarm bolt, and that's it,,, ?!
137453
I believe you are correct, bur it's a best guess - I would really need to see the part and how it fits the hole
Don't know where the swing arm pic came from, but what is the part number for key 36?
On the 500 2x4 models A01BA50AA and AB - part 36 (as on the schematic for the gear case) is 3233527 - I suspect the part 36 in the schematic of the swing arm is the same part number as in the drawing of gearcase.
I think it is the same part in different drawings.
My fault for not explaining correctly.
The part 36 (3233527) in the schematic of the swing arm that I've posted is the same part number as in the drawing of gearcase, I copied and pasted it into the swing arm schematic.
I was trying to demonstrate where part 36 will enter, next to the left side of the swingarm.
Still working the weekends on my red devil.
Loosening the nuts (7547031) on both axles was a nightmare, I had to ask a favor from a friend because alone at home I just couldn't do it.
Moving forward, everything loose and ready to assemble.
What's the best way to clean axle or shaft splines ?
I have a doubt, it is good to use copper mass on the splines of the rear axle ?
All the splines where water can enter and calcify the parts, it is good to use copper mass, right?
137526
And on the the driven clutch shaft ?
I'm assuming NOT to use copper mass on the drive clutch shaft right ?
