I have a 1999 Polaris scrambler i bought off a guy and the gears are backwards? So reverse is now hi range and hi range is now reverse? If anyone knows how to fix that it would be greatly appreciated. thanks
Welcome to the forums. Probably has the lever on the trans mounted wrong. The lever should be pointing to the right side.
If it is pointing to the left, remove the nut, pull the lever up and rotate it 180 degrees and reinstall. Buddy
Welcome to the board!
What did you come up with?
