1 - 2 of 2 Posts
I have a factory plow set up that came off a 03 Sportsman. My question is will it bolt up to a 08-09 Sportsman?
no. different frames, so you need a new mount plate. possibly though the blade attachement will still fit on the new mount plate. if anything, the blade should be able to be swapped over, but you will need to get the correct mount plate for that frame
1 - 2 of 2 Posts
