Polaris Speedometer Kit
16K views 12 replies 5 participants last post by  Polaris Magnum
I have a 2001 Polaris Magnum 4x4 with the 325cc engine. I know back in the day you could get a speedometer kit. Do you know if I could still get one, and if so, where? If I do find one, would it be relatively easy to install, or do I need to take it to the dealer?
Thanks for your help.
-Drew
#3 · (Edited)
To drewpul Hi,and welcome. I have a 95 425 mag 4x4, and am looking for the same thing,also a tach. If you happen to come on to those,let me know where to get it if you could?
Been looking around,and found a few speedo's on ebay motor's,but it seems they don't like to say what they fit! I am thinking of going to Google and look-up the part at a Salvage yard,those have been the places for hard to get parts!
Curt
Bayview,Idaho
cpspark@yahoo.com
#8 · (Edited)
Hi Drew:
I just found the speedo on EBay,and haven't even got it yet,,,is a factory fit and I already have a bracket and speedo cable there,so will be 2 bolts and hook the cable up. Think maybe I'll make an Aluminum schroud around it,so will be protected from objects breaking it again... Whoever was ridding it before I bought it,had to have run into a tree,or had the machine upside down,the bracket is bent a bit,although can be straightened easy. I bought it about 4 weeks ago,and haven't even ridden it yet. Have the carb off and just mounted a new fuel pump. I've had it running already,but not to the point of ridding,yet! Pretty soon,will be out climbing mountains here,,we have many of those,and are big one's!
I'll try and take a photo,once I get everything mounted,will send a photo when finished,,between work and everything else,as I travel for my work,being a Union Pipe Fitter! Gone most of the time.
Have you had any luck with your parts search yet,is sure plenty of those out there,best of luck!
Catch later,
Curt
cpspark@yahoo.com
Bayview,Idaho
#9 · (Edited)
Drew:
I found a speedometer for your 2001 Polaris mag, go to Best-price.com and type in Polaris speedometer, it's for a snowmobile,but should work on your mag,as it says it's used on other polaris's 2000--02,,,I also found a couple of gage cluster bodies on Ebay,they are for 325 mag"s,,They look like the one of the photo you put on here,,,I saved those on my watch list,and will get the link for you,if your interested?
Curt cpspark@yahoo.com
Bayview,Idaho
#12 ·
