Have a good one here . it will spark like made if spark plug is not in cylinder but as soon as you screw in into cylinder it loses spark.
How do you know its losing spark when you install plug....did you try spraying in some carb cleaner or starting fluid to see if it pops....just a little spray....it could be a fuel delivery issue if it pops...
Also is the spark you see nice an blue...and make a nice crack sound...thats a good spark if so...
I have seen plugs spark in the open but when put under compression they don't. Buy a new plug and try it. Worse case is you will have an extra spark plug.
Welcome to the board!
