1 - 2 of 2 Posts
So I have a 2014 Polaris sportsman 400 ho, I just replaced the solenoid, and my battery has charge and none of my fuses are blown yet I don’t have any kind of power, my lights don’t come on and my menu screen doesn’t come on when I turn the key. Any kind of information would nice thanks in advance!
Check for 12v on the yellow wire at the key switch - if none, check the 20 amp fuses in the fuse block - if the fuses are not blown, probe for 12v on both sides of the fuse when plugged in - if 12v on both sides of the fuse, the yellow wire from the fuse block to the key switch has lost continuity - sometimes just removing the fuse and installing will restore power.
If 12v on the yellow wire at the key switch, turn the switch on and check for 12v on the red/blk wire at the LH switch - if 12v on the red/blk wire, turn the handlebar switch on and check for 12v on the red/wht wire - let me know where this gets you.
1 - 2 of 2 Posts
