I just picked this 2007 Polaris Sportsman 500 EFI.
The clutch \ belt doesn't sound right. The noise goes away under no throttle, and after 10 MPH.
The history on this isn't 100%, it was obviously ridden hard, and put away wet. Sat for 6 or so years. Lots of work to get it running again.
Any ideas would be great.
*speedo is broken, and I am doubtful of the mileage
*and I posted to the wrong sub... oye
Doesn't sound too bad but you can't really tell much from the vids. It never hurts to freshen up old clutches though. Few people service them the way they should be. You won't really know what parts may need replaced until its taken apart, cleaned and inspected.
Scuff the sheaves and replace the belt when you put it back together.
to the forum
Your question has now been logged into the queue and the next available forum member will answer you shortly. You will be given more advice than you could hope for.
The real shortage in this country is common sense.
