Hello!
I noticed today that my beltcover and housing moves when i pull it, up and down 2-3 cm, is this normal? all bolts are thight, and the whole housing moves not just the cover.. And today i drove in deep water and no water leaks in to the housing...The atv rides fine, no strange sound...
Any suggestions?
They all do that.
The inside cover,which mounts against the engine and transmission, is plastic as well, so you will get some flex. Enjoy
Welcome to the board!
does it leak? try not to pry on it to excessively, it can cause your inner seals to leak(between motor and cover)
ok thank you. No it does not leak, but yesterday when i put my hand on the cover it was really hot?? or is it time to replace the belt? the atv goes fine good drag and topspeed around 90km/h.
cant answer that one for sure, but sounds like you have some excessive belt slippage somewhere, how hot is the air coming out the vent when u rev it up? probably a good idea to take the cover off and inspect everything
What year did they redesign the cvt cover? They were nartow, soft and flimsy. May be worth researchi g.
Sounds normal to me. They will flex and will also get hot when riding. So long as it don't leak and not excessively hot you're good to go.
