Bear with a rookie on this beast. What's the trick to remove the main seat on the 2013 Sportsman Touring 500 HO? The passenger seat has the release. I see no such release on the main seat to get at the spark plug or carburetor.
I think they all have a latch under the rear of the seat. From the top reach down the middle of the back of the seat and lift. If its the same as the xp's then it just pops up.
No latch on the touring. Just lift up hard on the back part of the seat and it will pop up. If you look from the back there are two rubber grommets that slide over some bolt heads and hold the seat on.
