· Registered
Ive recently started to have major problems with my polaris clutch. As soon as i go from Neutral to any other gear it started to drive when on idle.
Looked around and seemed like it was the primary clutch. So I bought a new one and installed it. Gave it a go and still same problem. But now it also dies after a sec.
Idle rmp 1700.
Will comment a video showcasing the problem.
· Premium Member
Idle rmp 1700.
to the forum
· Registered
Belt too tight? Did you replace the belt before this started happening? Check out engine and trans mounts to make sure nothing is broken or worn out causing the clutches to be out of alignment.
