2003 sportsman 700. Getting a .277A draw with everything off. Is that too high and what could cause it? No accessories. Battery is good. Ground is good. Getting good charge while running. But battery will die if not ridden. Doesn’t die if it is disconnected.
Check you rectifier/regulator. Disconnect the negative wire and put your meter in series with it to test for a draw.
Are you saying in series with the battery? If so yes that is where i see the draw. Or are you saying in series at the rectifier?
Update. My unit does not have a separate regulator rectifier. It is built into the control module. I did notice a fray on the yellow wire that would be part of the rectifier. But apparently there is no way to test this type of model.
