1 - 16 of 16 Posts
Is it in gear. I'm not familiar with your machine but my 2013 500 will not start in gear unless the brake is held. Yours doesn't have a park position I don't thing.
I think you're on the right track there. Gearshifter linkages are all good?
Run a wire from the - post on the battery to the starter mount and a wire from the + post on the battery to the post on the starter and see if the starter turns over.Also check the voltage of the battery I have already got 2 batteries that were bad new they were new.The key doesn't have to on to check the starter when it's wired right from the battery.
1 - 16 of 16 Posts
