1 - 13 of 13 Posts
Pilot jet in carb is always the first thing that comes to mind in this situation.
Pilot jet operates on the Venturi principle and clogs easily with varnish and gunk. I think cleaning the carb may help. I would take it to a professional if its beyond your scope of ability to do it.
You could also try a dose of seafoam in the gas as it can remove varnish build up.
Discussion Starter · #7 ·
Thanks a million. I have cleaned it and seen that the pilot jet was clear of any obstructions that I'm aware of. Will the pilot needle being out of adjustment cause idle to fluctuate or the pilot jet being clogged cause my problem
Sent from my LGL86C using Tapatalk
Discussion Starter · #11 ·
Thanks. When I took my carb off to rebuild it I did notice a clean crack right above the foot of the boot that attaches the boot to the cylinder head. The crack looked like two pieces put together to make one that eventually separated slightly. It runs across the bottom, from one bolt head to the other. It isn't where the intake and gasket mates up to the head, but the boot itself.
After seeing the crack while the carb was off I placed my hand over the boot and turned the engine over till I felt suction and stoped. While keeping my hand in place, the suction I felt didn't get any less. I held my hand there for about 30 or 40 seconds, and it still held. With that being said will the engine still experience an intake leak while running
1 - 13 of 13 Posts
