I'm new to the forum, but just viewed an old thread from Polaris_Nut about installing a winch. It was a very informative video, but did not address a question I have.
I recently purchased a gently used 2012 Polaris Sportsman 500 HO. It's in great shape with less than 600 miles on it! Going through everything, I found the handlebar winch switch operated backwards (Out was In/In was Out). I disassembled the switch thinking I could switch the wires to correct it. That can't be done because the circuits are all potted (sealed). While in the switch I noticed everything was pretty cracked up and decided to just replace the switch. I purchased the OEM switch from my Polaris dealer and installed it. Unfortunately, the winch still operates backwards. The only connections I haven't checked are the ones on the contact block. All the others are hooked up correctly. If the contact block connections are connected wrong (black on red/ red on black or yellow on blue/blue on yellow), that's an easy fix. If not, has anyone else experienced this issue, and what did you do to correct it?
