I know this a common problem, but what is the fix for the speedometer. My 4 Wheel Drive works fine, but the speedometer and odometer don't work. Is this an easy fix?
9 times out of ten, it's hall-effect sensor.
You can check the connections at the speedomter and look for any breaks in the wiring by the pickup, down by the wheel.
I believe yours is like my 97-425, speedo is cable driven, take cable loose at speedo and tranny , spin cable and see if its broke, check both ernds and make sure they are allright.
