This is the thread for the rebuild of my quad. Ive got some questions regarding parts and things i may want to change during this process.
list of things to address
1. Bent rear rim, Could i straighten it or just replace? I have been leaning towards getting some 12s for the rear for better tire choice.
2.Bent handle bars and steering shaft. Are the Polaris bars a universal fit or specific to each machine? And the steering shaft is there any chance of straightening it or just replace, If replace the same question as above. can i use the shaft out of similar years sportsmans or?
3. Chain needs replaced.
4.Headlight pod got destroyed. Now thing is i dont need a speedo, didnt work anyway. Although i know the AWD needs a signal from the speedo module, a ground i think? But I Noticed the Xplorer 300 4x4 doesn't have the Pod headlight or speedo, Could i convert to that setup? alot cheaper than replacing that Pod and gauge.
5. Busted CVT cover. Are they engine specific or do they interchange? pretty sure i just need the outside cover.
6. Plan on adding a winch and LED pods in place of the factory.
7. Both racks got messed up, What years and models do the racks interchange?
