2009 Polaris 700 XP EFI has been having some issues with smooth and/or top end acceleration. Read many a post
about potential issues and have check out most of them, best i could.
Most recent check was TPS. At idle, which was a bit low at 960 or so, the volt meter read 0.72volts. ( i probed the TPS
from the connector (YELLOW wire to GND). As I accelerated, voltage increase relatively smoothly. Didn't see any major jumps. At about 4000 RPM reading was only 1 volt?
I a couple of videos I've seen with guys checking the TPS, using the Polaris meter, the voltage range seemed to go as high as 3 volts when wide open. I didn't go to the floor on the gas, but was wondering if the 1v seems normal.
Thanks for your support.
