ive got a 2002 scrambler 4x4 and i just noticed today that my prop shaft to the front diff is loose seem that the shaft is just being held on by the roll pin the splines look ok form what i can see anyone seen this before?
from all the years of playing out in the mud,the yokes are the first things to wear out. I had to replace both of them on my expedition,they were loose enough that it was clunking as you were coasting down the hills .
easier to change if you take the radiator out ,that way eveything is out of the way and you can give the pins a good whack,to knock them out.
