1 - 8 of 8 Posts
I have a Predtor 500 with an annoying problem it will let the starter spin freely sometimes and sometimes it will catch and it sounds horrible. Any one had this problem if so where did you find parts to do this repair. Any help appreciated.:arg:
You can buy the starter parts from www.bikebandit.com among other places if you want to go that route or you can buy a starter for around $100 bucks or so,maybe cheaper.
And welcome to the board!
i have the same problem
That's for sure starter problem? if so Which parts i need to replace?it is the brushes?(I know there are STARTER REBUILD REPAIR KIT)
if not Could it be a one way clutch?or flywhele?or drive gear?
First off, welcome to the board!:cool2: And Shalom!
seem like it is the one way starter clutch found behind the flywheel.
same thing happened to me i already replaced the starter but problem still there,
so i opened it up and gears are all fine but it seem the clutch it isn't.
i been looking all around for it and i only found 1 on e-bay for about 130 bucks
1 - 8 of 8 Posts
