what are the stock size shims for the predator i am tring to adjust my vavles and the shims in the exhaust valves are 1.75 and the intake are 1.75 and 1.65
i cant figure out the size i need i did the feeler gauge thing and plugged it into the A=b-c+d and i got like .002 difference from the shims that are in it
any help would be great!
theres a list of manuals and the predator is in there...theres a whole chart that tells you exactlly what shim you need in replace of what you have
you simply need to take the measurement you got with you feeler gauges and figure out the difference between that and the spec, for example, when i did my ltz400 all mine were within spec except one intake valve, spec was between .1-.2mm and mine was at .254mm, so it was too loose, the shim that was in it was a 2.65. to get mine right within spec i put in a 2.75 shim which brought my clearance to aprox .154 nicely within spec.....hope this helps
