1 - 2 of 2 Posts
Hey how's it going guys. Just bought an '03 Predator 500. Just replaced the battery in it. & the issue is starting it. Once started it runs amazing & shifts great, but took off the side cover & only good part is the starter itself. Had a chip in the tooth of one of the idling gears near the starter & all metal shavings on the flywheel & cover & it wasnt looking to good, many scrapes in the metal part of the flywheel & also the starter gear behind the starter clutch seemed very loose & "chattered" against the starter clutch. So figured to get her good again today I ordered new idling gears, flywheel, stator, gasket, starter clutch, 8 new bolts, & a new starter gear. & i'll flush her out real good & clean out all the shavings. Am i missing anything, part wise ? Also when I replace the flywheel do I need to adjust the timing ? & also should I replace the woodruff key ?? Thanks in advance !!
Welcome to the board!:med:
1 - 2 of 2 Posts
