I recently purchased a predator and am having troubles finding the vin. I have looked behind the left front wheel below the oil tank and there are no signs of a vin or of a vin ever being there, there is also no sticker on the right front. I believe it is a 03 or 04. Is there any other locations or way I could find the vin. Anyone have any ideas where the vin would be located?
they are the only two spots that I have seen. I have tore mine completely down and haven't seen another vin number anywhere. what color is the frame? Has it been painted or powder coated? The stamped in numbers below the oil tank on the left side were so faint that when I powder coated it you can barely see them.
Thanks for the info, I will take another look at that lower left frame rail. The frame is black. Looks like a pretty thick coating from looking at a few chips, could be powder coat. Is there a good way to get it off without destroying the vin if it's underneath?
Welcome to the board!
