· Registered
Hello,
I have a 2009 Polaris Sportsman 800 efi and I need to replace the primary clutch cap (I had it broken). Can I purchase a different clutch with different part number and take the cap of (pic below)? The part number on my primary clutch is 1322749
Automotive tire Motor vehicle Rim Locking hubs Vehicle brake
· Premium Member
Font Line Window Pattern Screenshot
to the forum
Ball Gas Font Vehicle registration plate Automotive lighting
· Administrator
No - the cover is part of the assembly - and the unit is balanced with the cover installed. You can swap the cover with another and have the assembly re-balanced, but what cover will fit is unknown unless you buy an assembly with the same part number.
· Registered
Discussion Starter · #4 ·
thanks.. how do I re-balance the assembly?
· Administrator
Take the clutch to a machine shop with the capability to balance the it - search out a clutch manufacturer willing to rebalance the unit or contact a performance clutch shop who can spin balance it.
