I live in PA lots of plowing lately.. I will have to check them out you need the right one so the adjustment handle pin goes through..That can be true Kylle. When it comes to the plow. He should be ok. 29er just go in and ask someone. They are by the hardware. You need to know the size for your plow. You might have had a bad one, that's why it broke. They do not break that easy. Where do you live? Maybe if it was really cold.
My driveway is hard pack and 3/4 mile long. Between the driveway and the parking areas, it takes me about an hour with my plow truck. It went down and I had to use my 550 with a Glacier set up. Twice. No failures. Hit a stump at 5 mph, side angled to the left, no shear. The only time I broke the shear is when I hit another hidden stump at 12 MPH. Threw my ass off the ATV. Only damage, sheared pin.but see lots of "shear pin" issues.
I broke the two sides of one pin.. I live in PA... I checked for a replacement pin at the hardware store with no luck.. Had to buy a polaris pin which is ridiculous for $14..That can be true Kylle. When it comes to the plow. He should be ok. 29er just go in and ask someone. They are by the hardware. You need to know the size for your plow. You might have had a bad one, that's why it broke. They do not break that easy. Where do you live? Maybe if it was really cold.
