I have pulled all my calipers off my 2007 500 ho to make sure they worked and clean them. I had gotten them all back up to decent pressure. I had to buy a new rear master cylinder and am trying to bleed that line but I will not build pressure at all. I also had a heck of a time bleeding out the other 3 lines. Any tricks on bleeding these calipers. I have been bleeding them like I would a truck or car. Thanks
ive had to put a brick on the brake pedal over night in the past on other machines. helps get the air to the end of the line.
I had a prob with my aux. rear brake one time and i got air in the line between it and the rear cyllander. It took a great deal of pumping the brake lever before i finally got it. keep pumping and it should get there. I used a bungee cord on the brake lever when i did get some pressure as i was alone at the time. Good luck.
Mike
