· Registered
I am having a heck of a time trying to get the starter out. The service manual says there are two bolts holding it to the engine, but I can only access one, can't see or find the other one. I have removed the air cleaner box, recoil for pull start, rock protector plate and clutch cover. Is there something more I need to remove to access this thing? Any help is appreciated. Thanks
· Administrator
There is two bolts inside the recoil cover and two bolts behind the inner belt cover.
You have to remove the recoil cover, the outer clutch cover, both clutches and the inner clutch cover to get the bolts out - you have to get bolts #11 out of the upper part of the bracket #10 to be able to remove the starter motor.
Line Font Auto part Parallel Circle
