1 - 1 of 1 Posts
Okay I have low to no spark on my '88 Trail Boss 250 and can't figure it out. I have checked the resistance of the pulsar coil on the stator and it's within spec @ 120ohms. I checked from the pickup wire on the ignition coil to the ground and it's within spec at a very low resistance (can't remember exactly off the top of my head). Now it says check between the end of the spark plug wire with the cap off to ground and it should be @ 6300 ohms + more with cap. Now the multimeter I have only checks in 1k ohms and displays nothing on the LED when I check this. Also I have no power running to the ATV while doing these checks. Now do I have a bad ignition coil or am I doing it wrong? Thank you in advance.
1 - 1 of 1 Posts
